Need for speed Underground
Started by koper, 16 December 2003, 21:35:09
koper
Hi
This is my first post, i from poland and my english is very not good :)
I have one question.
First my komp:
Duron 800
192 SDRAM
Voodoo 3 / 2000
Sound blaster live
I cant play in 'Need for speed underground"
Why ??
Duron 800 Mhz / 192 SDRAM / 3dfx Voodoo 3 2000 / Sound Blaster live 1024
Hi-fi Technics "DOLBY SURROUND PRO LOGIC" 6x100 watt
What drivers/operating system are you using?
koper
System:
Windows XP Profesional
v3-w2k-xp-1.09-beta10
amigamerlin3.0finalbuildfull
Question : you had "mixed" the drivers ?
since the amigamerlin3.0finalbuildfull are for the V4/V5
koper
:) I don't know :)
Ok now unistal amigamerlin3.0finalbuildfull
and only install amigamerlin3.0finalbuildfull
Need for speed - i cant play :(
My question amigasport3.0finalbuildfull for voodoo3 ??
Sorry my english !!
:D :D :D :D
koper
Sory
and only install v3-w2k-xp-1.09-beta10
[:I]
Try uninstalling all your video card drivers, until your card is set as as Standard VGA controller or whatever, and make sure that you get them all out. Then install AmigaSport 3.0, and let us know what happens. AmigaMerlin 3.0 is not for voodoo 3 cards, only for voodoo 4 and 5, so it will mess things up for you.
WishBoy
i can't play a need for speed underground
driver: default of windowsXP (only sound play and nothing see)
driver: voodoolizer 1.05.00 WinXP 2K (opening NFS later auto-reboot pc "alone" :/
driver: amigamerlin3.0final (open nfs and crashed or "bluescreen")
my config
Asus CUSL2-C
P3 - 866MHZ
512MB
Voodoo 4 4500 AGP 4X
Windows XP (english version)
ElvIsAlive007
InSomNiaN
I'LL MAKE THIS CLEAR FOR EVERYONE.......[:(!]
IF U WANT TO PLAY NEED FOR SPEED UNDERGROUND WITH A VOODOO 4/5 VIDEO CARD, U NEED TO HAVE WINDOWS 98 INTSALLED.
FOR THE TIME BEING IT CANNOT BE PLAYED WITH WINDOWS XP! [}:)]
simon92922
i cant play Need For Speed Underground either...
my pc specs are:
Windows XP Home Edition
AMD Duron 1GHz
384MB SDRAM
C:, Total: 10.3GB, Free: 6.5GB
D:, Total: 46.8GB, Free: 24GB
Connection: Blueyonder Cable Internet 512kbit
GFX: SiS 630/730 64MB (On Board Video Card using 64mb from the 384mb sdram)
i am having problems playing it...
the startup movie plays but its a bit laggy.
as soon as im past that movie the user menu cannot be seen... the music menu in the bottom left corner is all blurred and the options on the right are all blocky and cannot be read.
I know games play because i have played Vice City.. and I think that game uses more power. I have no Setups on my CD for acceleration so if anyone has anything for me please help out :/
InSomNiaN
simon92922, plz post your issue in the non-voodoo gaming section of the forum.  ;)
--Doctor666--
hey all,
me too i ve got 1 problem...
after launching setup.exe the list of rendering 3D is emply!
why nfs dont found my V3 2000?
K7 800
256Mb Ram
A7V
Voodoo 3 2000
DX 9.0b
win 98
SB Live
K7 800
Asus A7V
512Mb PC133
Voodoo 3 2000 AGP @ Amigasport 3.0
eduardom
Hi, I think voodoo 2 and NFSU are working in my system, using the game 3d setup and selecting glide device the game works fine 800X600 pixels. I use windows XP and voodoo 2 drivers from 3dfxzone.
my sytem:
athlon xp 2600+
256 mb pc2700
Geforce 4 mx440 (worst card ever)
voodoo2
Need For Speed Underground doesn't support the Glide  ;)
What NFS are you playing ?
