directx9 and dfx card
Started by bendi, 27 October 2005, 00:29:29
bendi
I am looking for a voodo driver for my old dfx card (N 2544).
The newst one i found is voodo ver 5 but it supports only directx 8.
computer details( pentium 2 233 memory 128 sdram o.s windows 98 SE).
Thanks,
Bendi
you dont need dx9 on such an old pc.currently,there are few drivers that support dx8 and dx9 (partialy):
Raziel's Evolution driver for voodoo4/5 and win9x/me
SFFT driver for voodoo3/4/5 and win2000/xp
bendi
I cant get my hands on them.
Can you enclose a url for me?
Thanks,
Bendi
SFFT: http://www.3dfxzone.it/monitor/am/go.asp?url=88
Evolution: http://www.falconfly.de/vsa100.htm (look for Raziel64 Evolution Driver
Expert Edition V1.01.16 Lite)
once again,there is no need to have a dx8/9 compatible driver on a p2 233 with an unknown voodoo card (probably voodoo1/2/3,and certailny not voodoo4/5).
bendi
I tried them all but I still get the message that the adaptor doesn't support direct x9 (I need the support for one of my daughters game).
Are there other drivers to try?
Thanks,
Bendi
What's the game ?
and what's your voodoo card exactly ?
bendi
The game is sims2 and the card: 3dfx interactive N-2544
Thanks,
Bendi
there is no,excuse the language,no chance in HELL that game is going to run on your pc.if you want to play sims2,buy a new pc.howgh.
bendi
I had no problam running sims 1.....
well,guess what.quake2 ran great on my AMD K6-2 333MHz/voodoo3 machine.but quake4 just doesnt seem to run.weird,isnt it:D
you want to play new games=you must have a new pc that is able to run them.thats just the way universe works;)
bendi
Ok, thanks anyway for your time.
Bendi
