Problems with mine voodoo 2.
Started by Spectrobozo, 06 November 2003, 00:29:48
Spectrobozo
I have two voodoo 2 (monster 3d 8mb) but none is working in my new system! ATHLON and MSI k7n2 delta! what it can be? incompatibility! please help![:(]
Pentium 4 2000mhz+256RDRAM+MaxtorDiamondMaxplus9+Voodoo2 Monster 3dII 8mb
Voodoo 4 4500 PCI
2x Monster 3d II 8mb
3dfx reference drivers (win9x/3.02.02 too) have compatibility issue with Athlon processors so a good solution is  installing the latest FastVoodoo2 release for your OS.
If you need help, just i'm here.
Spectrobozo
but i try to use FastVoodoo 2 3.0 and 3.5 for windows xp.....
Voodoo 4 4500 PCI
explain what's happened
__________________________________________________
Network powered by 3Dfx and AMD
Spectrobozo
windows recognizes but when I go to play or stops the system or of the one menssagem of error
Voodoo 4 4500 PCI
"the one menssagem of error"
what's this message ?
Spectrobozo
something about memory error
Voodoo 4 4500 PCI
Quotesomething about memory error
hum, you must be precise ;)
