voodoo5 and rugby 2004?
Started by qrazi, 13 August 2003, 20:07:09
qrazi
does anyone know how to run this game? i downloaded the demo, but it gave me very bad graphical distortions. i also couldnt quit, but had to reset to get back into windows.
or has anyone found out some trick with another EA Sports game, recent one?
im using the 3dhq beta 10 drivers with win2k + SP4... i'd really like to play this game...
I have not tested personally this game or its demo so you wait for incoming drivers which could least improve the visual quality
qrazi
well, i found a solution to the problems. the graphical distortions were solved by alt-tab back in to windows and then back into the demo again. this cleared the flickering of the screen... i then could easily find out why i couldnt quit the game. it recognizes my joystick as a game pad, and my joystick happened to be not completely centered... and besides that, somehow the "s" key functions as a "enter" key.... my guess the demo is a direct port from PS2 code...
i could get some FPS numbers if anyone is interested?
you didn't try an other driver with a D3D core different ?
__________________________________________________
Network powered by AMD and 3DFx
qrazi
no, i use the 3dhq beta 10 drivers, but i do have the latest GlideXP files installed... but i have that setup longer then i have the demo, so it really shouldnt be because of that...
btw: fps were: 30 average, 19 min 70 or so maximal.
