Voodoo 3 3000 pci 720p movie
Started by kemanci_erdem, 10 August 2014, 05:36:27
kemanci_erdem
720p movie very slow any patch is faster?
Your problem is too imprecise.
Can you give more detail ?
kemanci_erdem
sfft 1.9 windows xp and 720p movie slow play
QuoteOriginally posted by kemanci_erdem
And your hardware is? What are you playing the videos in?
kemanci_erdem
3dfx voodoo 3 3000 pci 189 mhz oc
amd sempron 2800 64 bit 1.6ghz oc to 2.33 ghz
1.5gb ddr400 ram win xp pro sfft 1.9
youtobe video freezee
What web browser are you using? and what is your Internet speed?
kemanci_erdem
play game no problem high fps
internet speed 16mbps
chrome and firefox freeze
#7
I'm going to bet the cpu is playing the video and can't keep up. I also bet that firefox or chrome can't playback video with a voodoo 3.
Check your cpu usage with trying to play back video
kemanci_erdem
youtobe download 720p video and play vlc media player very fast no problem
internet browser freeze
#9
And your cpu usage when playing videos from youtube is?
I'm betting your system can't handle playing 720p video via flash in a web browser. VLC on the other hand is much better with hardware usege.
kemanci_erdem
Flash player  crashed blue screen
Old vga card No solution.
I english very bad:)
you cpu problem for flash
flash bad on pc x(
