Problem in FIFA 99 game crash when i make a goal
Started by Ricardo, 02 January 2005, 12:27:35
Ricardo
I have a P4 2.8 Lga 775 / 512 RAM / Graphic card onboard INTEL 828656 and CREATIVE VOODOO 2 12M PCI.
WINDOWS XP PRO SP2 (FASTVOODOO2 4.0 XP GOLD EDITION)
At the moment i'm working win the first glide drivers for windows 2k.:D
I don't know why this hapen but when i make a goal on fifa 99 the game and sound crash. but the keyboard works (num and caps) but i can't quit the game.[V] THIS IS ONLY WITH VOODOO2 [}:)]
If i play only with the 3d card (software render) the game works perfectly.
Ricardo
yes! 640x480 rules because i have a old display.[8D]
The original fifa99 supports only the 640*480.
Did you patch the game ?
Ricardo
No. i haven't patched it. when i choose 3dsetup, i'm only able to choose 640x480.
The is a ptach for FIFA99 to work great with glide drivers?:D
Yes, a patch exists.
It improves the support for the Voodoo2 and CreativeLabs.
(though i'm not sure that it will resolve your problem because never i played with this game)
