Voodoo2 320x240 support
Started by perer, 12 November 2004, 23:50:05
I know that officially the Voodoo2 doesn't suppport less than 512x348.
But the Voodoo graphics support 320x240, because the Voodoo2 is almost totally a voodoo graphics, wouldn't it support 320x240 then?
It is likely that the programmers just left out this low resolution because the thought it would be useless.
Does the Voodoo2 support 320x240?
That doesn't seem impossible since with a Wicked3D Voodoo2, you can reach 320*200.
And if i remember, with Quake2 and Sin, 320*240 are possible.
After, this is perhaps a problem of monitor, custom refresh rate...
Okay than it is probably disabled within the drivers.
