Voodoo 2 driver for windows 2000 (with direct3d )
Started by coolmaniac, 18 July 2004, 11:25:43
coolmaniac
hi all,
i have a pc running windows 2000 and i have two cards present on my pc (nvidia riva tnt and voodoo 2  )
the problem is that i cant find the right driver for voodoo 2 with direct3d enabled.
eventhough i have the 3d accelerator ..the peformance is very poor in games like Age of empires etc.
can anyone suggest how i enable direct3d ? and the right driver for my card ?
i think i have voodoo2 with 12mb ram.
any comments are welcome.
regards.
Hi, :)
Look that :
http://www.3dfxzone.it/enboard/topic.asp?TOPIC_ID=1174
You will understand where are the problems under the Win2k kernel for the Voodoo 2.
The best would be to come back under Win9x or a dual boot (Win9x/Win2k) or perhaps an other main gfx card.
What's your machine and with what games do you play ?
coolmaniac
Hi there,
Thanks for you reply! I plan to use win 98 .
That will be easier :) but not always easy probably.
Since i don't know your machine and games, don't forgot the limitations of the V2 : 256*256 textures, 16 bits, memory (8+4) ;)
Sanek
I have Diamond Monster 3D II (Voodoo2 from Diamond) and it works at 800x600 32Bit with MESAGL library.
Intel Celeron 433 MHz
128MB + 32MB RAM
40GB + 5.5GB HDD
ATI Rage IIc (poor D3D and OpenGL performance)
Dimond Monster 3D II 8MB 3D-Accelerator
Win98SE
Win2K Pro SP4 + Aston Shell 1.9.0
RedHat Linux 7.5
DirectX 8.1 (Win98)
FastVoodoo2 4.6 Driver Set
DirectX 9.0b (Win2K)
FastVoodoo2 4.0XP GE Driver Set
