Interesting Cooling Solution
Started by trigger, 06 August 2005, 09:17:53
roflkopp
Nope. These are Medion Geforce 3 Ti200 heatsinks. :)
roflkopp
QuoteOriginally posted by roflkopp
Nope. They are Medion Geforce 3 Ti200 heatsinks. :)
/edit: Voodoo3 heatsinks would also fit horizontally, but in black they are very rare.
And i like the idea to put Geforce heatsinks on a Voodoo 5. :D
Targaff
Quote/edit: Voodoo3 heatsinks would also fit horizontally
I presume like TM30's post up near the top in the thread?
I'm not especially well up on this sort of thing, so I'm wondering how these are fitted; any clues would be appreciated, since I'm looking at something similar myself as part of a quieter computer effort.  If anyone can give me an idea as to how well they cool, too, I'd appreciate it.
trigger
#34
Here are some shots of my Voodoo MAC Cooling Mod.
I couldn't get hold of the Vantec Iceberq Copper.
So I went with the Evercool Twinkling VGA Cooler.
All Copper Cooling Solution with priority on Cooling rather than quietness.
You can put less voltage through these fans to get the best of both worlds.
The Evercool Twinkling VGA Cooler was a tight fit. Especially the right VSA-100.
I had to loosen the fan when fitting to rearange the seating, because the caps would of had too much pressure on them.
http://www.evercool.com.tw/products/vc_re.htm
CoolerMaster Pure Copper Ram Sinks
http://www.coolermaster.com/index.php?url_place=product&p_serial=CRC-U01
BTW: I Cured my friends flaky 9800pro with one of these coolers. Cleared up all artifacts. Stable as.
I was so impressed I chucked one on my own 9800pro.
Benchmarked it before and after with much better 3DMark scores than stock cooling.
I think the VSA-100 will be Child's Play for these Coolers. ;)
Voodoo5 5500 AGP
Voodoo5 5500 PCI DVI x3 (exorcised MAC cards)
Voodoo4 4500 PCI
Voodoo2 1000 PCI x4 (two boxed and factory sealed)
Voodoo1
miroHISCORE 3D
Canopus PURE3D
trigger
#35
I'm thinking of doing an outrageous cooling mod next.
These bent into shape.
http://www.thermaltake.com/product/Cooler/VGAnCHIPnMEM/cl-c0034/cl-c0034.asp
Heatpipe technology arrives for V5! :D
Voodoo5 5500 AGP
Voodoo4 4500 PCI
Voodoo1
miroHISCORE 3D
Canopus PURE3D
