SFFT & Server 2008 x64 ( Vista x64 )
Started by Rhade™, 19 May 2008, 19:15:25
Rhade™
Hello,
At first: thx for this really good driver it works fine for me ( 2k3 x86 - 2k3 x64 - 2k8 x86 )
I have tested the sfft 1.0 release on my server 2008 rc1 x86 OS and the driver work fine. but on the testing relase from windows server 2008 RTM x64 - the driver dont work. I get a error message that the driver can't be loaded.
Is there a way to get it also working on the x64 version of the Server 2008 ( or Vista - its the same )
Thx for the hard work you do.
3dfx 4 ever :D
