voodoo3 display size problem
Started by bigguy05641, 07 December 2005, 22:53:38
bigguy05641
Hello, I had to reload W98 onto my pentium 2.The display device afterwards was a standard PCI graphics adaptor(VGA) which did not allow me to change my display size from 640x480, and it had only two color selections.I since figured out it has a 3dfx voodoo3 3000 display device, so I downloaded the driver from the dell website, and enabled as the driver. This seemed to correct the display size and color problem, until I restarted the machine, now the colors are all there, but the display size is back to being stuck on 480x640. Any ideas? Would not having the correct directx version cause this?Thanks, Steve
