Cooling Solutions, (HOMEMADE) :P
Started by Teh_Yabby, 16 January 2006, 06:52:50
Teh_Yabby
Hey,
Have you guys actually ever made your own type of cooling for Voodoo 2 cards, i want to make them look really awesome, i need some idea's!
Thanks guys!
You gotta love 3dfx!
Well I put some heatsinks on the bruce and chuck chips and on the ram chips too. I had to modify the SLI cable a bit so that it would fit.
But my way takes in a lot of room IMHO.
ArchAngelCD
If you are looking for some really great Voodoo2 cooling fans you might want to get the TennMax Stealth V2 Cooler. One fan covers all the chips on the V2 and it's thin so you can use your SLI without seperating the cards. Take a look here: http://www.tennmax.com/voodoo2/stealth.htm
BTW, the TennMax Stealth V3 Coolers are great for your Voodoo3 and Voodoo5 cards.
They are the best cooling fans I've seen for the V5... http://tennmax.com/voodoo3/stealth_v3.htm
____________________________
Funcod
offtopic
archangel i cant find your email could you contact me here funcod@ifrance.com i need to talk to u
from the tennmax website : Stealth V2 Cooler (not available))  USE Type 0 Cooler
( https://www.tennmax.com/orders/order_int.htm )
Teh_Yabby
Thanks for the replys guys, i might just design my own method of cooling i will post pictures when i have finished them.
skinnie
MSI KT3/Athlon XP 2400+/2x256Mb OCZ BH5/3dfx Voodoo 3 3000 AGP
nighty
I used the easiest method possible to cool my Voodoo2's:  single small fan attached with double sided tape so that it cools the v2 chip.  This method is illustrated on my very old 3dfx website for a V5 5500, but same principle (please turn pop up blockers ON!):
http://nightstormer.tripod.com/voodoo_article7.htm
My Voodoo2's were locking up constantly at OEM clocking, but with this mod they work perfectly :)
(4) Pentium3 PC's on a Voodoo2 LAN
