Voodoo4 4500 PCI MAC bios for PC
Started by trigger, 06 May 2007, 19:47:20
trigger
Does anyone know if there is a bios that exorcises a Voodoo4 4500 PCI MAC for use on a PC to enable DVI?
Or any information as to what to edit in the BIOS file to enable DVI?
It's been done with the Voodoo5 5500 and should be possible here too.
Anyone flashed a V4 mac with the PC bios 1.15 PCI?
Cheers!
Voodoo5 5500 AGP
Voodoo5 5500 PCI DVI x3 (exorcised MAC cards)
Voodoo4 4500 PCI
Voodoo2 1000 PCI x4 (two boxed and factory sealed)
Voodoo1
miroHISCORE 3D
Canopus PURE3D
Not only that, I have a Bios V1.18 for PC/DVI support.
I can send it to you if you like.
trigger
Thanks Rolo01 that be great if you could send it!
Is it the Voodoo 5500 Bios that states Voodoo 4500 by any chance?
Voodoo5 5500 AGP
Voodoo4 4500 PCI
Voodoo1
miroHISCORE 3D
Canopus PURE3D
No, it was compiled directly from the 3dfx source code by a guy named Rainbow, if memory serves.
To which email should I send the bios ?
pufans
Could someone please send me the Bios V1.18 for PC/DVI support for my V4 4500 MAC PCI? My email is: 1b10 @ inbox.lv
tnx,
Pufans
pufans
Many thanks Rolo01! Will proceed to flashing :)
pufans
