voodoo 3 3000 bios
Started by 3dfxFanatic, 24 January 2004, 16:18:22
3dfxFanatic
what is the best bios for the v3 3k sdram?
Anlisun
There's 2.15.12 which has agressive RAM timings and
there's 2.15.12m which has less agressive RAM timings and allows for better overclocking.
If you intent to overclock, then you should choose the second one. Otherwise, go for the first one.
