voodoo 5500 heat sink mod
Started by ms-dos, 05 September 2009, 01:29:34
i went and put rage 128 heat sinks on my voodoo 5500
here a pic that has the voodoo 5500 heat sink one top of the rage 128 heat sink
there is vary little heat on the card now
and dose anyone know if it is ok for the back of the card to heat up were the vsa 100 chips are
It`s normal, don`t worry.
All V5 cards behave like that.
well it can be overclock petty far i have yet to do sum tests on it    i can git to 185 MHz and its not that hot and its very  stable
