The Elder Scrolls IV: Oblivion
Started by Scrybe, 10 May 2008, 07:50:33
Scrybe
I have a Dell Lattitude D520, .99Ghz RAM, 80G memory, Intel Integrated 945GM Chipset Family. It doesn't have T&L. So I downloaded 3D Analyze.
Because my graphics card doesn't have T&L Oblivion will simply be a small black window, then an error report will pop up. That's when I tried searching for an alternative: 3D Analyze.
When I located my Oblivion .exe file (it installed perfectly), it didn't  initialize the game. What other programs can I use to fool the Oblivion T&L detection? It's for DirectX 9.0 (I have it installed).
You could try SwiftShader 2.0 :
http://www.transgaming.com/products/swiftshader/download/swiftshader_v20_demo.zip
But donĀ“t expect a good performance, because everything ( incl. Shader Model 2.0 ) is calculated by the CPU.
But hey, it ran on a Voodoo4... :)
