Amigamerlin: 2.9
Started by B00daW, 26 March 2003, 02:41:54
B00daW
First off, thanks for keeping the Voodoo alive and thanks for supporting it in English aswell.
I LOVE your driver.  It makes the Voodoo play so many games that it never used to with the original drivers.
Although, I have only come across one strange problem.
A majority of the important text in Age of Mythology will not display.  If you can fix that, I would be most happy.
email me at buddha(at)fefea(dot)org for a reply since i might forget to check back to the board.
thank you VERY much.
Buddha (B00daW)
