NEW VERSION of 3D Analyzer
Started by duocast, 20 December 2003, 22:10:04
duocast
Yep new version is 2.31 (build 316)
here are some release notes since 2.26:
v2.3 build (312)
- fixed a problem with AquaMark3 and the Deus Ex "Invisible War" Demo
- major GUI update, more easy to use from now on
- new hook code
- added "force windowed mode" for dx8/dx9
- added "spider-man the movie fix" for the voodoo 5
v2.3a build (313)
- fixed the "Can´t run the aplication because ForceDLL.dll couldn´t been found" error
v2.31 build (316)
- readded Win95/98/ME support, but some app+3DA will only work with winxp (Deus Ex 2 demo, Aquamark3,...)
you can get it at www.tommti-systems.com
"C makes it easy to shoot yourself in the foot; C++ makes it harder, but when you do, it blows away your whole leg."
- Bjarne Stroustrup
Still tnx for contribution :)
Current and older 3D-Analyze packages are available to download here, too.
