Look For This BABY :-)
Started by Ralf, 19 November 2006, 11:30:36
Ralf
3dfx Voodoo5500 Rev.A1 3000 With DVI out based on MT-55
Bios set standard 183mhz and agressive Timings Set
Max O/C 212 mhz - Stable
Cooling by 2 x Zalmans and Cu coopers + Fan Papst NGL2
Look for This Baby :D
1
2
3
4
5
6 - with Fan (Papst 92x92 1800rpm - 16dba)
7 - and in deskop (chieftec Bx - Big Tower)
8 - closer
powered by
Intel C2d @ 3,7ghz + P35
Very nice and Silent Modding !
212MHz stable !!! [:0] RESPECT ! ;)
Witch revision do the VSA100 have ?
220 or 320 ? ( maybe can u post also a picture without heatspriders ... if possible )
[8)]
Br.
Radu.
Ralf
F26059.1 AS
0028 20005
TAIWAN 1z01
why you ask ?
powered by
Nice speeds Raff3DC w000t, I suppose playing in reso 1024 x 768 x16 in many glide games you can now take advatage of the FSAA x4 setting or doesn't the performance increase differ that much compared to a cores/mem 166 Mhz card?
Only the revision 320 is afaik able to run over 200MHz !
( unsed on V56K )
I'm wondering that the older one, revision 220 like yours, is able to reach such an impressive speed !
Consider yourself lucky !!!
( I own two V5 5500, and tree V4 4500, and none of them is able to go over 187 MHz !! - they all have the revision 220 )
[:0]
BR.
Radu.
heh my VoodooMAC 5500 PCI 64MB Rev.A1 3100 with 6ns Toshiba ram did 191Mhz clean no glitches, but when OC to 195 or higher the glitches come by [8)]
Ralf
#6
hmm i think Ver PCI is better to O/C than AGP !!!
look for a cards PCB - Pci got more condenser and tranzistors
and more Voltage on chipset/mem -
Obi-Wan Kenobi change cooling on your Voodoo ;)
my Card in stock cooling overcloc to 195-6 mhz (stable)
when i changed cooling
arctic Silver 5 + Zalmans and Cu Coopers for Rams
boost to 210mhz !!!
powered by
hmm your advantage is the 5.5ns SDRAM I reckon, my ram is only 6.ns while yours is 5.5ns that does help in most occasions, but I rather keep my 3dfx cards original thanx, since that they are collectors items thier value will only be dreased when modded from thier original state, sorry.
Yes, I also think the 5.5ns ram is your ace in the hole for your OC speed increase.  The VSA's are rated by 3dfx for 200Mhz, but the 6ns ram has a top speed rating of 166Mhz.  5.5ns ram has a top rating of 183Mhz.
