Heroes 5 and pixel shader s**t :P
Started by Axar, 24 May 2006, 15:41:47
Axar
Hello
i have problem with this cllasick serie game  all works good (loading see animation of combat in menu,Duel mode works) but  campaign and scenerios doest run they loading to half  and crash to windows i know problem  is in Pixel shaders on map  ;s on beta i dont have such problems but ok
my spec littel moded ;]
cpu:p3 800Mhz
ram:512 sdram ECC
GPU: gf4 mx (that nasty one ;] )
Motherboard:Siemens d1107 [slot-1]
i use 3d analyzer 2.36b with some caps,one time i have black scr and i hear music and sounds ;p next time when i played with config i skip PS :F but game crash as always when  map is loaded :F
i try too NVEMULATE software like 3danalyzer dev by nvidia but i dont know ho to use it
well i know in 95% that i must buy new Videocard  but mayby  someone skip this ;]
Kopti
I have the same problem. I have Radeon 7200 128M. I dont wanto to buy new laptop. So pls help me to set 3D analyzer if it is possible. thanx.
_MireCZek_
Its alreday updated in new updates v1.1 and v1.2. Or you can go to the official forum about HOMAM5 and write there Intel 945GM - you can find there download contains repaired .exe - and than everything works great. This problem with HOMAM5 is with integreated or older laptot graphics
