Uninstalling Amigamerlin 3.0
Started by timtheenchantor, 26 October 2003, 20:02:12
timtheenchantor
How would you go about doing this, as I am going to be getting a radeon soon. So I would like to know how to uninstall it so I dont get driver issues with the radeon.
Also, how would you get ALL video drivers out? I did install the Voodoo4/5 W2k Driver(http://www.voodoofiles.com/2764), and uninstalled 3dfx tools, but I am not sure if I uninstalled everything.
So how would i uninstall Amigamerlin 3.0 and the Voodoo4/5 W2k Driver so I dont have driver issues from the new radeon?
well, I had AM3.0 installed before I installed my GF2. basically, what I did was uninstall the 3dfx tools, then used the XP search function to find files with the word "glide" in them, should be "glide2x" and "glide3x", and deleted them. worked fine, but I am reformatting now to get the detonator drivers out before i try to install the radeon, which is supposed to come in tomorrow[8D][8D]
