mitrovskiigi
Started by mitrovskiigi, 23 November 2005, 03:27:53
mitrovskiigi
I have WinXP and Ati Radeon 9600. Few days ago I get one VOODOO2 accelerator card. How can I make them run together because there is always some errors like "eror maping memory"?
Xasd
What drivers you use?
FastVoodoo and LegendGrafix are a good drivers for your Voodoo2.
mitrovskiigi
Now it is working. After I instaled FastVoodoo2_4.0_XP_Gold_Edition and fix for memory maping it worked.
P.S. Is it posible to do that under Windows 98?
there are no memmap errors under win9x,the recommended drivers will work fine (just make sure you copy in the correct glide drivers,as described on the helppage)..
