AVP2 & MW4:V
Started by Rogue Martyr, 10 August 2005, 20:46:32
Rogue Martyr
AVP2: custom detail, medium to high.. 1024x768x32
runs pretty well apart from on graphical error (as far as i can see..)
Mechwarrior 4: Ultra high detail.. 1024x768x32
runs very well apart from the fact it looks a bit sucky! it has the same problem with lighting. im no expert but im guessing it has to do with the vertex shaders.. you get this repetition of light across the texture.
Im using the latest Evolution drivers, Raziel64 u might be interested to look in to this?
MSi 645e Max
P4a 2GHz
512mb DDR 2100
Win98se
Voodoo 5 5500 64mb AGP
3Dfx Driver: 4.13.01.0028
3Dfx Tools: 2.6.2.166
3Dfx Bios: 1.06
(VSA-100@166MHz - hardware version: 001)
Rogue Martyr
can anyone see the screenshots? i cant. i used the built in image uploader.. im a missing something here? thanks
MSi 645e Max
P4a 2GHz
512mb DDR 2100
Win98se
3Dfx Bios: 1.06
Raff3DC
Nope, I don't see them either. Try www.imageshack.us. :)
Greetings from Germany,
Raff
Rogue Martyr
MSi 645e Max
P4a 2GHz
512mb DDR 2100
Win98se
3Dfx Bios: 1.06
Rogue Martyr
cheers buddy,
image shack works a treat! :)
try this one too.. im guessing its a shader problem perhaps
MSi 645e Max
P4a 2GHz
512mb DDR 2100
Win98se
3Dfx Bios: 1.06
Assuming that it is Mechawarrior 4 Mercenaries, So far as I am aware it runs ok under w2k/XP under my kernel. It seemed to be an Extended FVF parsing problem.
Rogue Martyr
Hi SFFT,
do you make drivers for win9x? i use 98se for compatability reasons. im partial to my older games :P
anyone else have any suggestions? :)
MSi 645e Max
P4a 2GHz
512mb DDR 2100
Win98se
3Dfx Bios: 1.06
