3D Analyzer and Planetside 2
Started by Warslasher, 04 December 2012, 23:02:25
Warslasher
Hi everyone. I am a total noob when it comes to computers. I'm a bit frustrated because I have a computer that can very obviously run the game Planetside 2 however the minimum requirements won't allow me access to the game even though the video card I have has all the necessary requirements. I simply need a way for the game to recognize my video card as a different video card to play. Here are my specs compared to the minimum system requirements:
"MinimumRecommended
CPU
Minimum: Intel Core 2 Duo E6850 or higher / AMD Phenom II X2 or higher
You Have: AMD Phenom(tm) 9650 Quad-Core Processor
Click here for the latest CPU drivers.
CPU Speed
Minimum: Info
You Have: 2.3 GHz
RAM
Minimum: 4 GB
You Have: 7.9 GB
OS
Minimum: Windows XP
You Have: Microsoft Windows 7 Ultimate Edition Service Pack 1 (build 7601), 64-bit
Click here for the latest Windows drivers.
Video Card
Minimum: nVidia GeForce 8600 series or higher / AMD or ATI 4850 series or higher
You Have: ATI Radeon HD 3200 Graphics
Click here for the latest Video Card drivers.
Upgrade Suggested
Features: Minimum attributes of your Video Card
                                Required  You Have
    Pixel Shader version    3.0      4.0
    Vertex Shader version    3.0       4.0
    Dedicated Video RAM    256 MB       256 MB
Sound Card
Minimum: Yes
You Have: Realtek High Definition Audio
Click here for the latest Sound Card drivers.
Free Disk Space
Minimum: 15 GB
You Have: 177.6 GB"
Could someone give me a brief tutorial of how with my specs I could get the game to see my video card as another one? I assume 3d analyzer is the best option which is what I've been trying to do and why I am here but I haven't figured out how to get it to run. It says I have the shader versions required and the video RAM. It just seems like they set the ATI/AMD minimum requirement too high so that even if mine meets the required power they still won't let me run the game.
Everytime I try using 3d analyzer it just shows a brief loading screen of the game then nothing. It was giving me an error last time but I reinstalled everything and it quit doing that. I am also not even sure whether the target path should be launchpad.exe or planetside.exe.
Thanks in advance for all your help guys!
