Voodoo 3500 VisualReality TV tuner
Started by maurice, 19 December 2004, 17:00:06
maurice
Hey, Pro's.  I brought this Voodoo 3500 TV card which has the 2 Coax ports and the DVI connector on the actual card.  I've correctly connected the fat blue cable and obviously got the monitor to work.  My question is:  One of those two Coax ports on the back are suppose act as a CATV input right.  But the 3DFX VisualReality TV tuner  software won't show me a picture regardless of which port I connect my live cable connection too.  Yes, the cable wire is hot.
Falstar
The Coax connector next to the DVI connector is for the CATV input. The other Coax connector is for FM Radio Antenna input.
xumin
yes ,the other is for fm radio input!!
V3 3500 is cool ,i like it,but i can't collecting it!!
there is seldom to select it in china market!
