geforce 6200 graphics card help
Started by robot22309, 14 February 2011, 22:34:24
robot22309
actually i have damaged my graphics card any idea how to repair it
bring it back to the shop,and see if the warranty is still valid.
maybe you should find someone in your neighbourhood who actually understands computers,as you clearly don't,and online support cannot fix everything.
btw,how did you manage to damage it? played baseball with it or something? [xx(]
robot22309
so it means that a graphic card cant be repaired
robot22309
i have read on lot of sites that baking graphic card in oven solves every graphic card problem the sad thing is that i dont have oven so what shall i do but i have gas heater so can i do it on gas heater and which plate shall i use and do i need foil also to put it on a gas heater please help thanks.
what is damaged
what is it doing wrong
we need more info
robot22309
when i install driver my screen goes blank and monitor turns off i have all the latest graphic card drivers any idea
QuoteOriginally posted by robot22309
thats a software problem not a hardware problem
did you run driver sweep befor installing the card?
can I get a link to the drivers ?
what os are you running?
robot22309
when i start my pc i get lines all over my monitor and cant boot to windows only safe mode is working please help
