May my username be changed?
Started by NitroX infinity, 23 April 2005, 22:03:00
May my username be changed from Phalanx to NitroX infinity?
It would be somewhat more usefull to me since NitroX infinity is the one I use the most.
Thanks in advance.
Hi Phalanx,
your username can be changed.
But, you think that many members know you just as Phalanx so changing your nick could create a little of confusion for those. This is mine idea only so, if you want, confirm here the new username and I will upgrade it.
Bye bye.
Is no problem, I can put in my signature that I used to be Phalanx.
And only the people on this forum know me as Phalanx, the rest knows me as NitroX infinity. :)
Also, just to make sure you get the name right; :D
The N and X are capital letters, the rest is all lower-case.
Done!
At last, imho, you would update your signature just as you wrote.
Tnx.
