making a sli cable grrr annoying!!
Started by RanCorX2, 20 May 2010, 18:06:11
RanCorX2
I've been putting together an old system and have 2 pci voodoo2 cards that I wish to use in sli but have no cable. I tried to follow an online tutorial to make one from a floppy cable but the pictures sucked and I ended up doing it wrong plus i manged the plastic connectors...ffs why are they so difficult to take apart?
Is there somewhere I can buy one that's pre-made?? or does anyone know of a good tutorial with hi-quality pictures?
they pop up on ebay occasionally,but are usually too expensive..they are quite difficult to make properly,I have destroyed 3 floppy cables until I finally got it right..I did make a small tutorial though,its here: http://forum.3dfx.cz/viewtopic.php?p=7349#7349
