How to really overclock your Voodoo 5 5500
Started by alex.turovsky, 25 May 2008, 12:32:19
alex.turovsky
It seems that the famous
V.Control overclocks only 1 of the two VSA-100 GPUs on your Voodoo 5 5500, so when you overclock to something like 220mhz and think you're tough, in fact you did almost nothing !
This is the only tool that overclocks both of the Voodoo 5 5500 GPUs:
VSA100 Overclocker from the developer KoolSmoky
a letter from the developer himself:
VSA100 Overclocker ver.1.00
April 3, 2004
Hardware: Voodoo4 4500, Voodoo5 5500, Voodoo5 6000
Platform: Windows 9x/NT4/2k/XP
Currently both V.Control (my bad! :P) and VooDoo5 Overclocker set the
frequency only on the first VSA100. So if you are trying to overclock,
the card will still run rest of the chips at factory settings and you
will see only a marginal improvement in speed since the card will run
as fast as it's slowest VSA100.
This tool will overclock *all* VSA100 chips on the card. The frequency
is set on-the-fly so no reboots are required. The chips will return
to factory settings when the PC is rebooted.
First install V.Control and copy files, VSA100_OC.exe.manifest, VSA100
_OC.exe, and VSA100_OC.dll to the directory of V.Control.
ex) C:\Program Files\KSmoky\V_Ctrl
Unload V.Control from the system tray.
Run VSA100_OC.exe.
The rest should be self-explanatory.
Note: VSA100 Overclocker and V.Control cannot be run at the same time.
If you have questions come visit the english forums at www.3dfxzone.it
V.Control is hosted at http://www.3dfxzone.it/koolsmoky
Enjoy!
Hiroshi Morii (KoolSmoky)
koolsmoky 'at' 3dfxzone 'dot' it
SO . . . in order to overclock the Voodoo 5 5500 we need:
1) download V.Control 1.82 beta
2) Download VSA100 Overclocker (and follow the order above, when the overclock itself is done from VSA100 Overclocker and not from V.Control(!)
both here: https://www.3dfxzone.it/dir/3dfx/voodoo5/tweakers/
P.S - my Voodoo 5 5500 project: http://www.iopanel.net/forum/thread12920.html
"He who controls the past commands the future. He who commands the future conquers the past". Kane,  Red Alert 1 1996
- Journalist of the Israeli PC Plus magazine.
- Personnel and Hardware forum admin in EDS Israel unit.
Please post here your voodoo5 Projekt !
I'm not able to read, only to look at the pictures :D
I see also that u cut the AGP slot on an ASROCK AGP8X board.
:D
Please give us more details.
Br.
Radu.
Atom_Anti
"VSA100 Overclocker is the only tool that overclocks both of the Voodoo 5 5500 GPUs"
I am not sure now[8)]. I was using 3dfx tool-->overclocking tab to overclock my Voodoo5. Did I overclocked only one GPU[?]. I do not think, because there was significant performance increase in 3DMarks. But if there is one more GPU power left, I am certainly going to use VSA100 overclocker[8D].
