voodoo5 5500 agp help
Started by namrepus, 24 June 2003, 00:00:57
namrepus
i have a voodoo5 5500 agp with win xp professional and i have some problems with gaming. counter-strike allows me to play but when i installed age of mythology, ut2003, and ragnarok when they are loading they begin to play then windows just reboots so i can never play. does anyone know a fix to this. plz help life sucks without games.
ACCEHu3ATOP
Install the last original drivers from 3dfx for Win2000 (version:v45-w2k-1.04.00). May be it help :)
ROTOR
Your problem is very easy to resolve.
unistall your aaaaactual driver and install amigamerlin 2.9 & reintall de last version of directX ( 9.0a )
disable gurdband clipping in the games.
please what is your actual driver??
if your problem continue try tu format your PC & reinstal WINDOWS XP
namrepus
girdband clipping?
using voodoolizer 1.05.00 drivers and im considering reformating as soon as i can get my hands on a cd
