Need help installing V5 5500PCI in Windows 7
Started by The Voodoo, 10 April 2012, 04:55:12
The Voodoo
I downloaded and installed the Sfft1.9 drivers. Setup went smoothly. However upon reboot Windows 7 will not enable the driver since it's unsigned. I tried signing them with this program - http://www.ngohq.com/home.php?page=Files&go=giveme&dwn_id=826 however Windows now says "Windows has stopped this device because it has reported problems. (Code 43)" instead of the driver not signed error msg.
Help would be appreciated.
What Edition of win7 are you using ?
Ultimate Edition ?
On 32 Bit or 64 Bit ?
The Voodoo
The Voodoo
Ok. Got it working by disabling driver signing before windows loads with F8.
