Wavy horizontal Lines~ Can they be cleared up?
Started by LW_Hearse, 02 April 2004, 07:43:14
LW_Hearse
Salute 3dfxer's
 While playing Red Baron 3d, I see faint horizontal lines waving back and forth on the screen. While these are not a big problem, I still feel image quality could be a bit better. Is there something, I might be missing to fine tune the image a bit so the waves disapear. I don't seem to have the problem with other games and image quality is very nice. Any suggestions?
Thanks ~ LW Hearse
Hi LW_Hearse,
these lines are caused by V-Sync setting: you can stop this problem and get better image quality simply turning off V-Sync (but a fps fall could occur).
That's all, good Voodoo2 gaming.
