How to change refresh rates with FastVoodoo 4
Started by Blazej, 28 January 2005, 22:46:40
Blazej
I have a question. How to change refresh rates with FastVoodoo4 drivers?. It is writen only "in registry Tools/refresh rates. I dont know where it is or how to change it. Are there any better drivers?
..get leinen tweaker from here: http://www.3dfx.cz/download/voodoo2_tweaker.zip (linked from www.3dfx.cz ),its the best you can have for the voodoo2.refresh,color,v-sync,you name it..
enthomologist
Well, if you feel familliar with registry (.reg) files, proceed to the Tools directory in the extracted FV4 package. There you'll find the folder called "Refresh_rate" and some .regs inside.
Their names are self-explaining: "800x600@85Hz" is 85 Hertz at 800x600 res. Double click to apply. Of course your monitor must support this mode; the latter "800x600@75Hz" will be the safe choice here. If you want to go higher,you can edit these .reg files by right-clickicking on them and chosing "edit", just remember the warning. Otherwise, look for Voodoo tweakers either on the main site or here: http://www.falconfly.de/
"The board authorized you? Hm. The board doesn't know the first thing about science. All they want is something to make them more money, a product. Don't worry...they'll get their product..." - dr Malcolm Betruger
